In Arc 3, when you tap on the map to view more detail, etc, the timeline pane would minimize so you could see more. That seems to be missing in Arc 4 - is that on the roadmap to bring back?
@crturboguy In Arc Timeline 4 the map and the timeline share the screen through the sheet rather than a tap: in the day view, drag the sheet down by its top edge, one stop per drag (twice from full height), and it settles as a small strip at the bottom with the map filling the rest; drag it up to bring it back. It’s recorded as BIG-860, with your vote on it.
@crturboguy A follow-up: in Arc Timeline 4 the map is live at every sheet position (pan, zoom, tap a trip or a visit) and the sheet moves by drag, so a tap on the map stays with the map rather than moving the sheet. In Arc Timeline 3 the map’s first tap opened it full screen, which is what slid the timeline pane away. So BIG-860 is closed; the drag from my earlier reply is the way to a full-size map.
