Arc Mini data migration
I have years of Arc Mini logs that I would like to export off an old iPhone. I’d be happy to pay for Arc Timeline 4 to enable this, but would it be able to get to this data?
@gerwitz, a question back first, because the answer turns on it: is Arc Timeline 3 (the main Arc app) also installed on that iPhone, and does its timeline show those same years?
Arc Timeline 4 brings history across from Arc Timeline 3 in two ways: directly from its database on the same phone (Migrate from Arc Timeline 3, in Settings), and from its iCloud backups (Settings → Backup & Restore → Import Arc Timeline 3 Backups). So whether your Mini years are reachable comes down to whether they’re also in Arc Timeline 3’s timeline, on that phone or in its iCloud backups, and that’s what the question settles. It would also help to know the old phone’s model and iOS version: Arc Timeline 4 needs iOS 26, and that decides which phone a migration can run on.
@gerwitz, a small addition while you check: Arc Mini recorded into the same shared database Arc Timeline 3 uses. Whether Arc Timeline 3 has also been on that phone, and the phone’s model and iOS version, still decide what Arc Timeline 4 can reach, so those answers are the next step.
I have Arc Timeline (and Arc Recorder) on that phone, but no active subscription. Is it safer to upgrade to 4 before subscribing? I.e. will an unsubscribed Timeline 3 appear to 4 as a database that should be migrated?
@gerwitz the subscription state of Arc Timeline 3 doesn’t come into it. Arc Timeline 4 looks for Arc Timeline 3’s database files on the phone, and an unsubscribed Arc Timeline 3 still has those, so it is offered for migration either way. There’s no need to subscribe to Arc Timeline 3 first.
On the order: a fresh Arc Timeline 4 install walks through its permissions, then the plan page (the app needs an active trial or subscription to continue past it, and the subscription plans start with a one-week free trial), and only then “Existing Data Found”, with Migrate from Arc Timeline 3 as the option. So there’s no ordering to get wrong: start the trial, and the migration offer comes next. The trial can be cancelled straight away if it isn’t what you want, and Migrate from Arc Timeline 3 is also there later under Settings › Backup & Restore if you pass it by at that point.
The one thing I still need is that phone’s iOS version (Settings › General › About). Arc Timeline 4 needs iOS 26, and if the phone can’t take that update, that changes the answer.
Thanks, robot. I was able to install Arc Timeline 4 on that phone, subscribe, and export the data
@gerwitz glad it worked out, and thanks for closing the loop.
