Ok, following up here with more detail, after sending you an email reply @Ward. But to recap the email:
I’ve now granted you Lifetime entitlement manually in RevenueCat. So you should be back up and going in the new app now!
Oh if the new app still shows the subscription view, tap the reload button (the refresh arrow thing). And if even that doesn’t work, swipe the app closed then restart it, and try again.
And now more detail:
Our suspicion at this point is that the old app hasn’t linked up the accounts properly. Well, that’s what we can see as proven in RevenueCat’s UI. Your customer profile there only knows about the new app, not the old. So yeah they haven’t linked up properly.
Our hunch for why that’s happened is that the old app might have only launched/restarted in the background, while the phone was locked. The “vendor ID” that’s required to link the two apps isn’t available when the phone is locked - it returns empty! Which we’ve just learnt today. Frustrating discovery! But at least it might explain some part of the mystery.
Both apps check and set that “vendor ID” when they start up, in order to ensure the two apps are linked. So the fix should be as simple as swiping the old app closed then reopening it. Because that will get it to start up again while you’re watching, while the phone isn’t locked. The vendor ID will be available, the accounts will link up.
At least, that’s what we expect if our theory is correct about what might be going on. Unproven, but it’s the best theory we’ve got at this point.
So yeah, next step is try that! Swipe the old app closed, reopen it, and …
Actually, now that you’ve been manually granted Lifetime for the new app, you probably won’t see any change. Hmm. Well, I mean, that’s fine. The goal is to ensure your Lifetime is available in both apps, and it now should be.
But doing the swipe close then reopen will still link the two customer profiles, which is still desirable. And then we can check in RevenueCat to prove that it worked. Which is important for other people who might be having this same problem!
And yeah, definitely let me know if it’s still not right. This time I’m super confident (I’m staring right at the Lifetime entitlement on your ID in RevenueCat now - this time it’s definitely there), but given this has been quite a run of bad luck, I’m still nervous!
And thanks for bearing with me while we worked through this. This whole transition to a new app, carrying over existing subscriptions and purchases, has been a first time experience. Have never had to do this for an app before. And there’s been a bunch of traps in it that I didn’t see coming!
