Later today I will plan to upgrade from my iPhone Pro Max 16 to the 18 Pro and was wondering If you could walk me though the exact procedure that you recommend that I follow. I am running the current version of Arc.
@Cestrius Hope it goes smoothly. Two things before you start, then the transfer, then a check.
Before: in Arc Timeline 4, Settings → Backup & Restore → Export Full Database. That puts a complete copy in iCloud Drive to restore from if anything looks off afterwards. Arc shows an “Exporting timeline data” screen; leave it open until that goes away. And don’t erase or trade in the old phone until the check below has passed.
The transfer: when setting up the new phone, choose “Transfer from iPhone” (the direct phone-to-phone option) rather than “Download from iCloud”. Keep both phones powered and next to each other until both say the transfer has completed; if you have a USB-C cable to connect them, that’s quicker and steadier than Wi-Fi for a large database like Arc’s.
The check: on the new phone, open Arc Timeline 4 and look at a few days you remember well from years back (a holiday, an old home), and check that the earliest day in the Timeline’s calendar is the same on both phones. If it all matches, you’re done. If it doesn’t, Settings → Backup & Restore → Restore Arc Timeline 4 Backup, and pick the newest folder in iCloud Drive › Arc Timeline › Exports › FullDatabase. If the subscription screen appears on the new phone, tap Restore Purchases on it: your Lifetime is tied to your Apple Account, so that fetches it straight back.
If you’ve already done the transfer, do the check. If anything’s missing and the old phone still has Arc on it, run Export Full Database on the old phone now, then restore that export on the new one.
Thank you Claude for the very nicely detailed answer and everything transferred - Yay!
With that said now it seems that if forget to open the app, and go somewhere, it will still think I am at the previous location so what I have to do for now is try to remember to open Arc 4 before I go anywhere. I am I gave it all the permissions it requested.
@Cestrius Glad it all came across. Arc records in the background without needing to be opened first. Two things will show us what’s happening on your phone:
A screenshot of Arc’s Permissions screen: the gear at the top left of the map, then Permissions. If Location there says “When In Use” rather than “Always”, that alone would produce what you describe, so it’s the first thing to rule out.
A diagnostics export for a day it happened: on that day’s timeline, tap the ⋯ button at the top right of the map, choose Export Diagnostics, tap Continue, and send it to matt@bigpaua.com with a note that it’s for this thread. It shows us what Arc was doing while you were out.
Post the screenshot here and we’ll take it from there.
I will email you the log file as instructed next time it happens.
Here are the screenshots of location under settings. When I tap on location, it doesn’t show me what its current setting it is on, only what each settings mean.
@Cestrius The green tick beside Location Services means it is set to Always, which is the setting Arc needs. That screen only spells a setting out in words when something needs changing, so a tick on its own is the good state. Tapping a row opens its description rather than the setting itself.
So Location is set correctly, and the diagnostics export is the next step. On the next day it happens, as before: that day’s timeline, the ⋯ button at the top right of the map, Export Diagnostics, Continue, then send it to matt@bigpaua.com with a note that it’s for this thread. It shows what Arc was doing while you were out.
Oddly enough in a good way, it seems to have sorted itself out but will email you as instructed If it should occur again. Have a great day and enjoy your daily run.
As per procedure instructions. I have emailed you the Diagnostic logs under this thread it ws mentioned. The section between Brand / Laurel Canyon and Insurance Agency Automation Associates was a lot longer than 12 minutes and included a 44 minute bus ride and an almost 20 minute stop at Pavilios Market that wasn’t even recognizd. Thank you.
@Cestrius Thanks for the exports; they show what happened. The stretch you describe, and another later in the afternoon, match times when Arc wasn’t running: it stopped at about 11:39 and again at about 13:40, with no record of how, and it ran again only when you opened it, at 12:39 and 16:55. Nothing was recorded in between, which is why the bus ride and the stop at the market aren’t there to bring back.
The one rule worth knowing: Arc needs to stay in the app switcher, the screen of open apps you get by swiping up from the bottom of the screen and holding for a moment. Going to the Home Screen or into other apps is fine. The thing not to do is swipe Arc’s card up and off that screen, which stops the recording, and iOS can’t be relied on to start it again. Closing apps that way rarely helps the battery and often costs a little more. You also don’t need to open Arc before going out; leaving it in the switcher is all it needs.
If you see a Data Gap, it’s best to leave it as it is. A gap is Arc showing a stretch it has nothing for; marking it as stationary tells Arc you stayed put, so the visit next to it grows to cover that time.
If a stretch goes missing again, send that day’s export the same way and we’ll look again.
