How do I export 1 day, 1 mont or 1 year in gpx format in the new app?
Hi @POM!
GPX export isn’t yet available in Arc Timeline 4. It’s planned for the upcoming v1.1 release (issue numbers are BIG-292 and BIG-396. Both are filed as high priority).
The only current export format is JSON (Settings → Backup & Restore → Export Full Database), which unfortunately won’t be useful for Google Earth.
Thank you .. I will wait then.
Will all months be downloadable later, when version update has taken place?
/Per O.
Yep! The feature (BIG-292) exports all the way back to earliest data, and keeps it updated automatically.
This feature is now complete, and will be arriving in an update hopefully later this week!
Thank you very much![]()
Best regards
Per O. Madsen
I still miss the monthly files. Last one is april 2026. When Will May and june be available?
Best regards
Per
@POM Hi Per! The monthly files were the old app’s format. Arc Timeline 4 does it differently: it exports daily and weekly files instead. The monthly files got too large to keep reliably updated in the background, which is why they were retired.
So there won’t be May or June monthly files, but the same data is all there. In iCloud Drive, look in the Arc Timeline 4 folder, then Exports. You’ll find Daily and Weekly folders, each with GPX inside. The weekly files are named by week number, like 2026-W27.gpx. For Google Earth, the weekly files are the closest replacement for the old monthlies.
And if those Daily and Weekly folders aren’t there, check Settings → Backup & Restore in Arc Timeline 4 and make sure the auto export options are switched on, then give it a little while to catch up.
