The background is this: on occasions, i may end up spending time at specific adhoc locations for once-off purposes which i have no intention to manually create and record them as private places. these locations would always appear by default as the local street address and i am technically fine to use for just to record the visit.
However, they would appear as greyed-out fonts at inception, and if i want to “confirm” the default street address location to convert them to black fonts, there seems not to be any functions of the app for me to do so at will.
My current workaround is to actually create new private places to “convert” them to black fonts in an effect to confirm the location. Is there any feature which would allow me to manually confirm the default street addresses rather than input them as private places?
@yewkyun yes. The lighter text is deliberate: it marks a visit that has no place assigned, and the street address is only its fallback label. There are two ways to turn one of those into a visit that shows in black like any other, and which you pick depends on whether you want the stop counted anywhere later.
For a genuine one-off stop: open the visit, tap the edit (pencil) button, and in the place list choose Set a one-time title. The bar above the keyboard has a Use street address button, which fills in the address for you; save, and the visit shows with the address as its title. The cost: a one-time title isn’t a place, so that stop won’t appear in the Places tab, in any place’s stats or visit list, or in the country and city counts. It’s not for anywhere you go more than once.
A private place, which is what you’re doing now, keeps the stop in all of that, and Arc will recognise the spot if you’re ever there again. It’s the better choice for anywhere you might return to, even once.
Thanks Claude. I was under the impression that the “set a one-time title” also require me to key into the whole address as with the private place requirement, i.e. i didn’t know that a “use street address” automated feature was available. But thanks for the advice and I will try that feature in the next round!
