Timeline Cleanup: Use street adress
Hi Matt and Claude,
Cleaning up my timeline every day is still quite a hassle. Especially the option “Use street adress” for an formerly “unknown place” (nowadays the automatically determined address is usually correct / sufficient) requires a rather annoying series of 6 taps all over the screen, including the cleanup tap (3-star button*) which is needed almost every time. I’ve highlighted this tapping sequence in the screenshots with green / yellow “fingerprints" (I tried to rearange the imgage order several times but the last three stay in disarray.).
It used to be easier… before Arc Timeline 4 or even 3. I don’t remember exactly. Is there a way to streamline this process?
*I get why cleanup and confirming can’t be combined as Claude described Matts design ruling here: Arc 4 daily workflow UI musings - #5 by claude
Proposed solutions
My first idea would be to add an option “Use street adress for One Time Visit Title” in the long-press menu for visits of uncertain items. Now the only options is “Delete visit” (there used to be more options like “Add new private place / Set one time title / Mark as bogus”).
The second suggestion I would make is to simplify a few steps:
  1. Why can’t the address that’s already been automatically determined serve as the default option for a one-time visit without me having to explicitly select it? If I want to replace it with a custom entry, I’d have to enter this anyway.
  2. Why do I have to explicitly close the confirmed one-time visit to return to the timeline cleanup screen? This isn’t necessary when confirming other visits or trips. If, by some chance, I want to make a change, I can simply reopen that entry.
Side note regarding suggested locations
I don’t understand why Arc so often suggests locations that are obviously too far away (for example, the ones circled in red in a screenshot). I don’t see any benefit in displaying potential matches that are hundreds — or often even thousands — of meters away. In my opinion, this contradicts Arc’s claim of having high accuracy and an intelligent learning engine. But perhaps that’s a topic for another thread.
In any case, I’d like to thank you for your ongoing work on this app, and I look forward to your responses regarding my main issue.
Greetings from Berlin
midor
@midor thanks for the screenshots; they made this quick to check. One piece of it we’ve filed as BIG-926: after you save a one-time title, the app drops you back on the place picker instead of the Cleanup list, which is where every other choice on that screen lands you. That’s the extra back tap.
The two options below the suggestions do different jobs. A one-time title is a label on that single visit and nothing more: the visit has no place behind it, so it doesn’t count in the Places tab, doesn’t appear in any place’s visit list or stats, and Arc won’t suggest it for later visits. It’s meant for one-off moments like “stuck in traffic”, which is why it isn’t applied by default. For a spot you’ll be at again, Add a new private place is the other option: it’s a real place, so it counts everywhere a place does, and Arc then assigns that spot by itself. The next visit there either skips Cleanup altogether or arrives already named, and then it’s two taps from the list: long-press, Confirm place. It costs a little more the first time, since you type the name yourself, but only once per spot. For a genuine one-off the address title is still the right tool, and BIG-926 is the extra back tap on that path.
That’s also why the long-press on that row only offered Delete: a visit with no place has nothing to confirm yet. Once it has a place, Confirm place appears there too.
@midor BIG-926 is in 1.8.0, out now (release notes in #1445): saving a one-time title from Timeline Cleanup takes you back to the list, like the other choices on that screen. It’s a phased rollout, so the App Store may offer it before it updates by itself.
