I just had to replace my iPhone due to the original being destroyed in a fall. On the old (now destroyed) phone, I had recently upgraded to Arc Timeline 4, but left the old version installed “just in case”. I don’t recall if 4 recognised my existing subscription (it was over a month ago) but I suspect it must have done so - I don’t see a new subscription for it that started at around that time in the system settings subscription section.
But after restoring my iOS backup to the new phone, the restored 4 doesn’t recognise the 3 subscription - and that only just renewed (6 June - while I was without a phone waiting for the replacement to arrive) so there’s nearly 12 months of it to go. 4 is confusing in that it doesn’t appear to clearly state that the old subscription is recognised. Other apps have a “restore purchases” feature - can’t that be added here? I accepted the free trial on 4, thinking it would pick up the old subscription but it didn’t - it said it would start billing on June 16. So I cancelled that, but what happens when the free trial of 4 expires? Will it pick up the older paid subscription? Seems a bit confusing.
Hi adg. Good news first: your subscription is fine, and nothing here will cost you anything. What you’ve hit is a known wrinkle with phone replacements, and there’s a straightforward fix.
The mechanism behind it: Arc Timeline 4 recognises your Arc Timeline subscription through a link between the two apps that’s established per device. When your new phone restored from backup, Arc Timeline 4 came across, but the link to your subscription didn’t, because the old Arc Timeline app hasn’t checked in from the new phone yet. The subscription itself is safely attached to your Apple ID, which is why it renewed on June 6 without any trouble even while you were phoneless.
To get Arc Timeline 4 recognising it again:
Open the old Arc Timeline app on your new phone. If it didn’t come across in the backup restore, reinstall it from the App Store first. Opening it is what re-establishes the subscription link on the new device.
If you want to be thorough, tap Restore Purchases inside the old app (on its subscription screen). That forces a fresh check.
Then force-quit Arc Timeline 4 and reopen it. In Settings → Subscription you should now see it showing your subscription as managed through Arc Timeline.
On the free trial: nothing to worry about there. Since you cancelled it, it simply runs out on June 16 with no billing. And once the steps above are done, your access comes from your existing Arc Timeline subscription anyway, so the trial expiring is a non-event.
On Restore Purchases: Arc Timeline 4 does have a restore button. It’s on the subscription page, the circular arrow button at the bottom left, next to the purchase button. Though in your particular situation it wouldn’t have done the job on its own, because the restore needed to happen in the old app first, per the steps above.
I got the iPhone Duo and tried to restore my subscription, but it didn’t work. I ended up signing up for the free trial. I don’t have the old Arc app on my phone anymore. Is there not a way to do it without installing the old app?
@jersh there isn’t a way without it: the link that lets Arc Timeline 4 see an Arc Timeline subscription is made per device, by the old app, which is why Restore Purchases in Arc Timeline 4 on its own can’t see it on a new phone. The subscription itself is fine; it stays with your Apple Account.
So on the Duo: install Arc Timeline (“Arc Timeline - Trips & Places”) from the App Store, open it, and when it asks for location, While Using is enough (that stops it recording in the background alongside Arc Timeline 4). Then in its Settings tab open Subscription Settings and tap Restore Purchases. Then open Arc Timeline 4 again: in Settings → Subscription the row should read “… · From Arc Timeline 3”. If it doesn’t, say so here before you cancel anything. I’d leave the old app installed afterwards.
Once that row shows, your Arc Timeline subscription covers Arc Timeline 4, so cancel the free trial at least a day before 13 November, in iOS Settings → your name → Subscriptions → Arc Timeline 4, so it doesn’t start billing.
Matt wrote about why the link needs the old app, and about an optional sign-in that has been considered for carrying it across, which isn’t settled (BIG-901), in #1428, posts 18 and 19.
@jersh One thing that might be an option is cancelling the old Arc 3 subscription and getting a refund from Apple, given it only renewed recently. Though I don’t know how long Apple let yearly subscriptions run before they decide they’re not refundable. But if they do allow the refund, then you can switch to a subscription in Arc 4, and not be tied to the old app at all any longer, and also not be paying for any overlap so no wasted money in the move.
