Arc loses view state
Please make Arc stick with whatever app/view/not sure the terminology here state user has chosen while it’s active and do not reset. This is confusing, so I recorded a video to demonstrate - iCloud Photos - Apple iCloud
I open Arc, make it show the map full screen, then swap to Maps, then back to Arc - and Arc resets to small map. Super annoying as I’m trying to find the location on the map.
Ah, I thought this was going to be a case of Arc discarding its UI in the background because it got a memory warning. But this is actually the “close full screen map when going into the background” - a bit different.
Ok, yep, understood! The reason why it does this is so that when you come back to the app you’re not just confronted with the full screen map with no context of anything else. But that only really makes sense if you’re coming back to the app minutes later, when you might have already forgotten what you were looking at or doing. Doing it immediately, as Arc is doing now… doesn’t really make sense.
I’ll make a note to change that. Thanks for the heads up!
