Export Full Database is not Working
I just started using the Arc Timeline and wanted to test how the data export works. I have a 1+ days worth of data with 8 places tagged. Although once I try to export all of the folders are coming to my icloud as empty. Also for a split second it shows the screen for exporting but then it disappears. There is clearly something wrong with it. It says on the debug logs in order:
[00:17:46.249] [EXPORTING] ExportManager: Found 3803 samples from 2026-04-19 01:51:15 +0000 to 2026-04-19 23:16:48 +0000
[00:17:46.334] [EXPORTING] ExportManager: Samples export completed (3803 samples in 1 weeks)
[00:17:46.335] [EXPORTING] ExportManager: Extension ‘notes’ exported 0 records
[00:17:46.338] [EXPORTING] ExportManager: full export completed in 0.2s
Somehow it doesn’t get that 3k+ samples. Would somebody help me to fix this?
Hi @wiseywisey1234! I replied in the other thread. The log info there all looks correct. Please check the samples folder in Files app on your iPhone.
If you are checking on your computer, then be aware that iCloud Drive can take time to sync from iPhone to computer.
