Hello,
I’m opening a support request because I seem to have lost access to all my Arc data after trying to move to the new app.
Device / environment
iPhone 15 Pro
iOS 26.4.1
Same Apple ID throughout
Apps that were installed before the issue
Arc Timeline
Arc Recorder
Arc Timeline 4 final version (the one available on the App Store)
What happened
I was blocked in the new app on the last onboarding screen. When I tapped the “Continue” button, nothing happened.
After that, I found a support post suggesting that uninstalling and reinstalling the old app could help the new app detect that I already had a subscription. Because of that, I deleted all Arc apps at the same time. And then re-install Arc Timeline 4 first, and then the others.
Before doing that, I had already enabled iCloud Drive backups in Arc since many months.
Current situation
Now I no longer see any of my previous data in either the old app or the new app. Both appear empty.
What I currently see in iCloud Drive
I have two top-level folders:
Arc App -
Arc Timeline
Inside Arc Timeline I have:
Backup
Inside Arc App I have:
Backups -
Export -
Previous Backup 328ED865 -
Import
Some of these folders appear to have been modified recently, which makes me think the data may still exist somewhere and that this could be a restore/import problem rather than a full deletion.
What I already tried
In the new app, I tried using the import function and selected both main backup folders.
Each time, I got a loading/progress screen, but when the visual loading finished, nothing was restored and no data appeared.
Important point
At this stage, there is no visible historical data anymore in either the old or the new app.
What I need help with
Are my data likely still recoverable from the existing iCloud folders?
Which exact folder should be used for restoration in Arc Timeline 4?
Is there a known issue where the app shows a loading screen during import/restore but restores nothing?
What is the safest next step from here, without risking overwriting or losing the remaining backup files?
I can provide screenshots of:
the iCloud Drive folder structure
the empty state in the apps
the folder contents if needed
Thank you.
