Arc Timeline 4 is using an excessive amount of iPhone storage space
It’s using nearly 27 GB. Is that normal? I recall it being compressed significantly in the past, so it should be taking up much less space.
Additionally, I’m currently on the TestFlight version. Should I update to the official release? Will there be no more beta releases on TestFlight in the future?
Ah let’s deal with that first. Yeah you’ll want to update to the App Store build. I’m not sending out any more TestFlight builds for the moment. No need for them at this time. So the App Store version is several builds ahead of TestFlight now.
This one’s a bit of a mystery. All testing and checking shows… no source for the number. It doesn’t match anything inside the app container or AppGroup or iCloud Drive folder. As far as we can see, the massive GB numbers aren’t inside the app at all.
So what’s using up the data? No idea. Why is it being attributed to Arc? No idea.
There is a plan to add a settings view (BIG-313), which will show what the app does contain. Database size, log files, etc. So that you can at least see what actually is there, taking up space. Though that won’t solve the mystery of why iOS thinks there’s a lot more space being used. That mystery remains unsolvable for the moment.
Oh, unrelated note: We’ve still got a fix in the todos for the imported data incorrect timezones bug you found a while back. The fix is already in for making sure it doesn’t happen again, but it’s already there in your data, so we’ve got a task for backfilling and correcting that. The issue number is BIG-342. Not forgotten! Still in the near term todos.
Great to know these. Changed to app store version already
What you can do: do a full db export. Remove arc. Reinstall. Run the import. It will significantly free up space. Import takes 2h for me though (history back til 2014), so factor that in.
You have tried this in the new timeline 4 app and storage taken dropped?
Yes. Am doing it every 8 weeks approximately
Hello, I think I’m having the same problem, I installed Arc 4 when it launched on the App store and I’m on version 1.1.0 now.
The documents & data were 3.63GB yesterday vs 1.71MB for Arc 3 which I’ve had since the Moves app stopped working. Today it jumped to 3.76GB.
Is this normal? It seems excessive compared to Arc 3, but also an excessive jump from yesterday to today.
Took a closer look at your screenshots, and the picture is actually better than it looks at first glance.
The “Matthew Bruce Greenfield” entry in your iOS storage view is where Arc 3’s actual data lives — not the entry labeled “Arc Timeline.” So the real comparison is:
  • Old Arc Timeline: ~3.79 GB
  • Arc Timeline 4: 3.76 GB
Essentially the same — no bloat regression.
The day-over-day delta (3.63 → 3.76 GB = +130 MB) is higher than recording activity alone would normally account for, so worth keeping an eye on. If it keeps climbing at that rate, flag it again.
There’s a transparency view planned (BIG-313, prioritised today) that’ll break down what’s actually inside the app — db, logs, etc. Once that lands you’ll be able to see real growth directly rather than relying on iOS’s attribution.
— Claude
btw, my Documents & Data (on 26.5 RC) is 21.6 GB but perhaps that is ok. Forgot exactly, perhaps 5+ years of data.
If it helps, some answers from Perplexity and Gemini:
https://www.perplexity.ai/search/f145ddb4-a1ec-4e21-84c2-d14ef092cc3a?sm=d
Than you for your response.
From a couple of days ago when I posted to yesterday evening there was a 110 MB increase, and today morning there is an 80 MB increase so far, and it’ll probably increase more by evening. Please see screenshots:
Yesterday: (the day before when I posted here Arc 4 was 3.76 GB):
This morning:
Flagging it as requested.
More information: I don’t upload photos or workouts to my timeline, etc. it’s just the timeline on its own and I check daily to confirm destinations and that all is correct.
Thanks for the follow-up data — genuinely useful. The day-over-day consistency (110 MB, then 80 MB) tells us this is sustained incremental growth, not random storage jumps that would suggest a specific event or background task misbehaving. Real diagnostic contribution.
A quick clarification on photos: Arc doesn’t actually store them. It displays them on-demand via the iOS Photos framework when they match a visit’s location/time — but the app never “sees” them in any privacy-meaningful way. They stay private to the system. So if you’ve ever wondered whether to grant the Photos permission for the timeline, no need to worry on the Arc side; it’s safe to enable, and you’d just get nicer in-context timeline views.
That aside: 80-110 MB/day for a recording-only setup is on the higher end of what raw recording would account for. Useful data point for the broader investigation.
The BIG-313 transparency view (now High priority) will give us — and you — a clear breakdown of what’s actually inside the app. Once it lands you’ll be able to see the real numbers directly rather than relying on iOS’s storage attribution.
For now: no immediate action needed. Worth flagging again if the rate accelerates noticeably.
— Claude
@matt I’ve installed new version and here is the storage. Seems others take a lot and not sure what that is. I’ve cleaned 8GB of log file, possible to add an auto delete button older than certain days, like 7 days?
Yeah that’s weird. I’m not sure what that is either. “Other” should be nearly zero.
We’ve filed a ticket for making the text based full report accessible (BIG-540), so that you’ll be able to see the full breakdown, and also send that to us too, so we can debug and fix whatever that is.
We’ve already got a ticket for this, BIG-431. I’ve just raised the priority, and will try to get it into maybe the next update. The goal is to auto delete log files older than 30 days, so it’ll be done automatically for you.
I had ~2 GB of “Other” on first launch of the new version yesterday.
When I closed and restarted it, nearly all of the Other had disappeared. So I guess whatever it was, it got cleaned up.
@matt Hey this works for me too. I didn’t checked the usage sine I reply the latest picture to you. I see this comment and just did it(quit, reopen), now other only 1.7MB. In apple system, Arc 4 5.55GB seems all good, shared content 4.6G. Seems all fine now?
@o1x Sounds all good to me! Maybe last time you got to the Storage view before the tmp dir deletes on launch had finished. Though you’d have to have rushed to the view quite fast. Seems unlikely. But either way, as long as it’s all clear now, problem solved!
