Long time Arc user that migrated from Moves. I’ve had a long-standing issue where it seems that my moves data had a single day from January 2013 with a little bit of activity in it, I’m guessing I used Moves once to check it out, then nothing until regular use in February of 2014. So I have an entry that spans 12 months, 7 days that is essentially garbage. Currently still on Arc 3, on an iPhone 15. Just picked up an iPhone 18 Pro, and trying to determine the best course of action/order to:
a.) clean up existing Arc 3 data before moving to Arc 4?
b.) transition to Arc 4
c.) get transferred to my new iPhone 18.
@crturboguy The order that works best is b, then c, then a, and it comes down to one fact: Arc Timeline 4 reads Arc Timeline 3’s data directly on the same phone, so the move to Arc Timeline 4 happens on the iPhone 15, before the new phone comes into it.
- On the iPhone 15, make sure it’s on iOS 26 (Arc Timeline 4 needs it), plug it in, and install Arc Timeline 4. If setup asks you to choose a plan first, tap Restore Purchases, which fetches an existing Arc subscription or Lifetime purchase straight back. When it shows “Existing Data Found”, tap Migrate from Arc Timeline 3 and keep it open and on screen until it finishes. Arc Timeline 3 and its data stay as they are. (If you skip it during setup, Migrate from Arc Timeline 3 is also in Settings → Backup & Restore.)
- Check the result in Arc Timeline 4 on the iPhone 15: a few memorable days from years back, and the earliest day in the Timeline tab’s calendar matching Arc Timeline 3’s.
- Settings → Backup & Restore → Export Full Database, and leave the “Exporting timeline data” screen up until it goes away. That’s the safety copy.
- Move to the iPhone 18 Pro with “Transfer from iPhone” in its setup, not “Download from iCloud”. Both phones powered and side by side until both say the transfer is complete; a cable beats Wi-Fi for a large database.
- On the new phone, open Arc Timeline 4 and do the same check as step 2. If anything is missing: Settings → Backup & Restore → Restore Arc Timeline 4 Backup → the newest folder in iCloud Drive › Arc Timeline › Exports › FullDatabase. If it asks you to choose a plan, Restore Purchases does the same there.
On the cleanup: there’s no need to do it first. That item comes across as it is, so tidying it can wait until you’re settled on the new phone; if it won’t budge then, post a screenshot here. Keep the iPhone 15 as it is until the check on the new phone passes.
