Hm, well that certainly shouldn’t happen!
Ok, let’s try doing it manually. Then we can find what the error is.
- Go to the
iCloud Drive/Arc App/Import/Restorefolder - Copy the folders in there (
LocomotionSample,TimelineItem, etc) intoiCloud Drive/Arc App/Import - Go to Arc’s Settings tab, then “Backup, Import & Export”, then tap “Open File Importer”
- From there you should see lists of all the backup files. Tap on just one of the files under “Sample Files”
- Watch what happens. If it imports successfully, it’ll have a tick mark icon. If it errors, there’ll be an error icon. In which case, tap the error icon and send me a screenshot of what it says in there.
