Read closely — your Moves findings are now in our support notes for the next Moves-era arrival. A few real answers back:
The hidden-data question: yes — overlapped originals stay in the database and do count toward its size until their import is removed. That’s deliberate: they’re what makes an import reversible. Every import can be removed whole (open any item from it → its details view → the GPX Import section → the red Remove), and removal restores what that import displaced. With several imports layered over each other like yours, I’d remove them one at a time and check the timeline after each — overlapping imports interact, so step-and-check beats bulk removal. Either way, the experiments aren’t permanent weight.
Why the activity sub-labels didn’t take: Arc reads a track’s activity from the <type> element on each track, exact-matching its own vocabulary — the same names you see in the app’s type picker, lowercased (walking, cycling, running, car, train…). Moves’ older per-day layout keeps activity info where Arc doesn’t look, and “transport” isn’t a word in Arc’s vocabulary, so those land as Unknown. Since you’re already tweaking the files with Claude Code, the fix is cheap: have it write Arc’s own type names into each split track’s <type>. Moves’ walking/cycling/running map straight across; “transport” needs a per-track judgment call, or leave it Unknown and re-type in-app — Unknown trips are first-class citizens, no nagging.
The “no places” problem is the format’s ceiling, not your pipeline failing: a GPX track carries only the path — no information about where you stopped — and waypoints import as single-instant visits, which is likely why the combined file still doesn’t look right. The recipe that works for Moves-shaped data: have Claude Code fill each long time-gap in a track with a small cluster of points at the stop location, spread across the gap. Then Extract Visits (the map pin icon in an imported trip’s details view) finds those clusters and creates proper visits with real start and end times. Two tips that make the whole pipeline land cleanly: point Claude Code at LocoKit2 on GitHub so it sees what Arc expects, and make sure every point carries a UTC ISO-8601 timestamp in time order.
The choke on the full 6.5-year file: valuable at-scale data — could you say what it actually looked like (an error, a hang, a crash)? Splitting by year is a sound approach regardless, so no need to retry the big one for our sake.
On the original Moves importer: there’s no script to pass along, I’m afraid — the old app’s Moves import wasn’t a converter or a script; it read the Moves export straight into that app’s own database, so there was never anything standalone to hand over. The GPX route you’re on, with the tweaks above, is the right shape.
