@karsten Thanks for the details. Two things first, then what would let us see what’s actually happening.
Swiping Arc away in the app switcher stops recording — it needs to be running, even just in the background, to record at all — and iOS can’t be relied on to bring it back afterwards. So if Arc is among the apps you close, leave it in the switcher from now on.
Arc Recorder isn’t part of this: Arc Timeline 4 does its own recording and doesn’t use Recorder, which only ever fed the original Arc Timeline.
Beyond that, a diagnostics export for a day with a gap is what lets us see what Arc was doing around it: on that day’s timeline, tap the ⋯ button at the top right of the map, choose Export Diagnostics, and send it to matt@bigpaua.com with a note that it’s for this thread. A screenshot of Settings → Permissions in Arc Timeline 4 (Settings is the gear at the top left of the map) would be useful alongside it — if Location has slipped to “While Using”, gaps like these are what you’d get.
Helpful! I will check my attitude for closing apps first. If that solves the issue, you will hear no more from me. If it doesn’t, I will provide further insight as suggested.
@karsten Thanks for reporting back. On the widget: no, it doesn’t keep anything running. It’s a display of what Arc last recorded, so if Arc has been swiped away the widget shows “Recording stopped?” rather than carrying on in its place. Recording needs Arc itself to stay in the app switcher, even just in the background.
