Ok that sounds promising!
Yeah, multiple Previous Backups folders is common. If you ever turn off then back on Arc’s backups setting it’ll rename the previous Backups folder to Previous Backups, same as it would during a fresh install of the app.
What I think I’d do at this point if figure out which Previous Backups is the newest one. Then hopefully that one has all the sample week files in it, in their most recent forms.
Though if it’s not that clear cut, like the most recent one doesn’t contain everything, then it might be time to get creative with possibly doing multiple restores, starting from the oldest folder then working forward in time. But in the hope that the newest folder is complete (or complete enough), I’ll move on to describing the import process.
So … I think in this case I’d actually jump straight to doing a manual import/restore. If there was only one Backups folder or one Previous Backups folder I might lean towards the auto/managed restore. But yeah, in this case, the manual. So to do that:
- Copy the chosen Previous Backups folder into the Import folder
- Reinstall Arc, go to the Settings tab, Import, Export & Backup menu, “Open File Importer”
- You’ll see the various import files sections fill in with all those files
- Start by tapping on the most recent sample week file to import it. This will also import any necessary TimelineItem and Place files that those samples depend on.
- Go check in the timeline view that that data has come in cleanly. If not, do any necessary cleanup at this point, to get that data looking sane.
- Repeat this process for each week file, working backwards in time. Though if things are going smoothly, you could tap a few week files at a time, though always working backwards in time, so that there’s never gaps in the timeline that the processing engine might mistakenly attempt to heal over.
Oh, one detail that’ll be useful to keep in mind: Some useful things need to be automatically rebuilt after the data is imported, and this might not happen immediately. The most relevant one being the “activity type models”, which are the things that the activity type classifiers use to automatically determine the activity types of samples that haven’t been explicitly confirmed as one type or another (eg walking, running, etc).
That means that earlier on in the import process the timeline processing (or rather activity type classification) might act quite dumb. It won’t be able to sensibly determine activity types. But that should be quite brief (or at least ideally so, if iOS is playing ball). As soon as that data is imported Arc will ask iOS to run a scheduled task to start updating those data models. And if iOS is being kind it will run that task almost immediately.
Anyway, yeah, after first week or two of import if you notice the timeline data acting a bit weird, with really odd or nonsense activity type assignments on some items, that’s why. No need to panic! You can fix those assignments by going into the edit views, and once the data models have ben updated Arc’s own auto assignments will settle down, back into sane choices.
Oh you can also at any point in the process import the Notes files. Those are harmless to do at any stage, and should all import in a second or two. You can also import the TimelineRangeSummary files at any point, though those are almost entirely useless. They exist essentially only to preserve knowledge of which days you’ve marked as favourites. If you don’t us the favourite button on days ever, then those files contain nothing of interest.
So yeah, the sample week files are the core of it all. The Notes files are, well, your notes you’ve added, and the TimelineRangeSummary files contain info on which days you’ve marked as favourite. The other files you can ignore - importing them won’t do anything useful, and they’ll be auto imported anyway, as needed.
Ok so if looking at the Previous Backups folders you get the sense the most recent one isn’t as complete as hoped in terms of sample week files, then let me know and we can start thinking about a possible multiple restores flow, or even merging folders as you suggested. Though if it comes to that we’ll want to make careful decisions. So yeah, I won’t dive into those details yet, in the hope that they won’t be necessary!
