I have button outlines enabled in the Accessibility System Settings. I think Arc 4 has some sort of rendering problem with this setting. See the two attached screenshots. (I’ve blacked out some personally identifying information.)
Yep, the first one is a known issue, and filed for fixing in an update soon. I’ll double check which update it’s filed for… yep, filed for v1.0.2, so fix should be coming soon.
For the second screenshot, with dates slightly off screen, that’s curious. Do you have iOS font size slightly larger than default? It doesn’t look especially large, but I wonder if that’s what’s causing it. It looks like timeline view isn’t coping well with the different font size.
Actually I might already have something filed for that too. I’ll check… Yep, there’s something filed for essentially the same issue, just with slightly different presentation. That’s also filed for fixing in v1.0.2, so should hopefully arrive soon!
I do have a slightly larger default font. Looking into this further, it appears that the slightly off-screen digits only appear when there’s an entry with 4 photos. Not just three shown inline, but the first two shown and then the “+2 more” sort of indicator/placeholder.
