Arc Editor public beta 12
The Arc Reader build is 875. This version may include Stationary as a heatmap option (I’m not sure if I pushed it to Github yet) That particular feature still has issues, but the other activities should still be OK!
Re: Python PhotoKit wrapper to access my Photos library on Mac.
I have a few other projects that run local servers, but for Arc Reader it’s a setup hassle for users who just want to click the Github link. Fortunately, I can still access the photo library and make multiple selections via the normal Apple Open dialog by scrolling down to the media section.
I’m about to add a heat map feature to my Photo locations program that I’ve been using for mapping koalas. Unfortunately a Photokit wrapper would not help with that one because I always take several photos of the same Koala and that would mess up a frequency heat map.
Gordon
I also added the heatmap function to the photo-mapping program I use for tracking Koalas on Mt Gravatt in Brisbane. Unfortunately Arc Reader doesn’t support 3D mode :pensive_face:
I’m developing an LLM interface on the Analysis Page. I will push it up to Github later tonight hopefully. At the moment you will need a Claude API Key to use it.
I’m currently looking at optimisations to reduce the tokens used, but it depends on the type of query. I also included the option to use Claude Haiku 4.5 since most queries shouldn’t need a lot of ‘intelligence’. Sonnet 4.6 is overkill. BTW, using Haiku reduced the cost for the same query down to $0.0058; much more reasonable!
I’m now adding a simple map interface so that Claude can show results on the map e.g. “Show me on the map, all the locations I visited this week. Exclude work and home.” I’m not sure what that will do to the token count? I guess I’ll soon find out!
I’m really excited about this feature!
PS: One potential issue is that the function results are uploading to Anthropic, so a user should not ask some questions e.g. “where do I live?”; that would send the exact GPS location to Claude. I’ll need to add a warning.
Regards
Gordon
One thing I wanted to mention here: @zzGordon , I think your app is still missing handling of bogus samples, see Filter bogus GPS samples from distance calculations and map display by PalminX · Pull Request #6 · gordon-williams/arc-timeline-reader · GitHub
My PR has gone stale against your latest changes, but maybe Codex can figure it out by itself.
This is exactly what I want to add to Arc Editor!! I trialled it in a new side project the other week, and it worked out fantastically well. So it’s high on my todos to do something similar in Arc.
And now you’ve gone ahead and beaten me to it again :joy: Though I think there’s some specific benefits to also doing it outside of the app. The constraints are different, so both approaches hold value.
I found the same in my side project app. Also if you haven’t already, make sure to have extended_thinking enabled. Haiku really excels when it can use thinking tokens to plan out its approach.
With extended thinking, I’ve found so far that there’s nothing Haiku can’t nail. It doesn’t struggle at all. And as you say, it’s also absurdly cheap compared to the others.
Me too. It’s something I’ve been thinking about for a while, but had filed as “later; maybe never”. But with my recent side project and the significantly better than expected results there (and Haiku’s capabilities being also far better than I’d expected)… It now feels like a high priority, extremely high value feature.
I am effectively creating an Arc Reader API for the LLM to use, so it’s a game of ‘Whack-a-Mole” to expose all the data the LLM will possibly need to answer user questions. I’m also doing this due to privacy issues of potentially sending exact GPS co-ordinates to Anthropic. To get around this, I only send location names and cache the GPS data locally. When the LLM comes back with the results, the app merges the GPS data to create the map, table etc.
Note: Haiku 3 goes away in April
Here’s an example ‘chat’. It’s doing things, that the main program can’t do as easily. Note the costs are shown after each interaction.
Yeah the workaround I did with Arc Editor’s Haiku powered search view is that Haiku interprets the user’s query and turns it into filters, then the app applies those filters on the app/client side. So Haiku never sees the user’s data, only the user’s search query.
You’re not using Haiku 4.5? It’s a champ!
Yeah exactly. To build all this power into the main app (Arc Editor or Arc Reader) would be unworkable to impossible. But give the AI the necessary tools and it can apply intelligence to unlock a breadth of functionality we could never build otherwise.
Oh now I see Haiku 3.0 is significantly cheaper. Hmm. I guess usage and pricing will be something we feel out over time, in both apps. Hard to predict ahead of time what token consumption is going to look like.
I have other models available in a dropdown menu. I can up the model for more complex questions, but so far Haiku 3 has been effective and so far my whole development of the feature has cost me USD $0.47 in tokens. I’ve also spent a lot of effort optimising the efficiency of the query process. There’s also a Claude option called prompt-caching where subsequent calls within the same conversation are 90% less expensive.
Gordon
Yeah prompt caching is worth a lot. Though have to be careful to move all the dynamic content as far down the context as possible. And make sure it doesn’t change between API calls. That’s the first failure I always see - cache hits not happening because something in the prompt is subtly changing on each call.
I just added an MCP server option to Arc Reader. There’s still some work to do though. The default database doesn’t include GPS data although the option is there, but it may crash if you have several years of activity. It still can do quite a bit without it.
Here is an analysis of my top 15 hardest walks over the last 12 months using Claude Sonnet 4.6 High. Since I was using the MCP connection in Claude Code, it created an interactive javascript page to display the results of my query. Of course, none if this would be possible without Arc Editor / Timeline.
Very cool @zzGordon! As usual you’re doing some really fun stuff that I wish I could do myself :joy:
We’re actually building some basic Claude Haiku integration into the next Arc update.
Well, Haiku’s technically already in there, doing super basic query interpretation to translate “cycling 2025” into activityType: cycling, year: 2025, for search result filters. But the goal with the next update is to give Haiku a bunch of tools so that it can answer more complex questions in its own voice.
So far it’s just simple stuff, like “how many cycling trips per month in 2025”, “what’s my longest trip this year so far”, “which month do I visit Starbucks most often”, etc. A bunch of query and aggregate tools, all read only.
I suspect at some point the in-app functionality will converge towards what you’re doing. Though I’m not sure they’ll ever meet in the middle. Where your app is running opens up a lot more possibilities for flexibility and more advanced functionality. And what makes most sense to do in a chat view in an iPhone app is I think inherently more limited.
That’s similar in concept to the Chat Tab on Arc Reader’s Analysis page. There are several built-in functions (tools) the AI can use to answer basic questions. The problem was anticipating the wide range of questions users might ask. I found myself playing a game of ‘Whack-a-Mole’ coming up with more and more tools to address new questions.
When I first created the Analysis section of Arc Reader, I just wanted to have a natural-language interface to the Arc database (an LLM between the user and the database) and let it build the tools to answer any question. Smarter AI models are needed for that, so not ideal from a cost perspective, therefore the toolset was created to allow lesser models to produce reasonable results.
But more recently I discovered custom MCP servers and the possibilities expanded beyond my expectations, and I haven’t even added my GPS data to the exported database yet!
BTW. The toolset is also embedded into the MCP server.
Regards
Gordon
Yeah Claude and I went through this chain of thought too. And our conclusion was basically that because you’re working from a db copy, on desktop, you have both the freedom and safety to go big. While with us on mobile and working with the user’s primary database, we’re more constrained both in how powerful we can build and in how much risk we can take on.
Oh we actually meant to have a look at your Chat Tab code, but didn’t get to it. I forgot to get back to that.
Anyway yeah, I think inside the app we’re inevitably constrained to that approach of building out tools, whack-a-mole style, dealing with each new case of “Haiku says it can’t do that because it doesn’t have the tools”. And shipping small, safe, incremental improvements over time. Carefully crafted queries and response shapes behind the tools, that can be shipped to all users.
While on your side you can go big, and should go big I think. Full power, full smarts, full flexibility. And yeah, the MCP server approach then gives you that to connect to Claude Code and Codex. Super cool!
@zzGordon I had never seen this before. This is so helpful. And it’s much faster searching for historical tracks on the computer than phone.
@matt I reckon it would be useful for you to link on Arc App to both this support forum (because otherwise one of those things where you only know, if you know), and have an FAQ or something similar pointing users to extras like this. (My gratuitous 2¢ worth.)
@elucubrator Hah! I’d totally forgotten the website even exists :joy:
But yeah, agree, the website should be linking both to the forum here, and also ideally to third party tools like @zzGordon’s. (Just filed this, ticket number BIG-569).
I think there’s actually a few now. People building some really cool stuff.
I wonder if it’d also make sense to use the Announcements category here on the forum for release notes, updates etc, for third party tools. Not sure if the current permissions allow anyone other than me to post under that category. But I’ve certainly got nothing against people announcing and discussing their Arc related things here. It’s all good stuff.
