Arc Editor public beta 11
@twilldre This sounds like a great use case for map views on the Activity tab. Old Arc Timeline had this, and it’ll come to Arc Editor eventually too.
So the goal will be that Timeline tab shows all - visits and trips together; Places tab shows only Places; Activity tab shows only Trips. And Activity tab is pending the addition of map views.
@feron Yep, can install Arc Editor alongside Arc Timeline. I have them both running. They record to separate databases.
Arc Editor can also import all of your data from old Arc Timeline, bootstrapping it with a full timeline. In the current build you get to that from the “Old LocoKit importer” on Debug Info view at the bottom. In the next build (maybe coming today) it’ll be from a proper Settings view for Import/Export/Backup stuff.
@matt : It would be great, if you could add the widget also for Arc Editor
