I came across a bug I can reproduce quite reliably.
After a search, if I choose a visit then go back 2-3 days tapping the “<” button, the timeline shows the maps for the day, but the trip/visit list is from the previous day. The same thing happens when I pick a date from the calendar, and go back several days. Sometimes even going back just one day triggers the bug.
All my tests jumping forward kept the map and the list synchronized.
I’m running Arc 1.7.8 on an iPhone 17 Pro with iOS 27.2. I can share videos of the bug if it is helpful.
@lmpinto thanks, that’s a clear one, and a repeatable sequence is exactly the useful part. Filed as BIG-936.
Yes please to the videos: the forum only takes images, so email them to matt@bigpaua.com with a link to this thread. If a recording runs on for a while after the list goes wrong, that may answer the first of two questions by itself: once the list and the map disagree, does it stay that way, or come right at some point, and if so, after what? And does ‹ ever do it when you start from today, with no search or calendar pick first?
@lmpinto got the four recordings, thank you; they’re with BIG-936 now.
They settle the first of my questions. Once the list is a day out, opening and closing an item cleared it in one recording and not in the others, and while it stays out, further ‹ taps keep it a day out. In the first recording, › brought the two back into step. The second question (whether ‹ from today ever does it with no search or calendar pick first) is still open, but there’s no need to record anything more for it; if you happen to notice it, a line here is plenty.
(My answer apparently wasn’t sent before the videos)
I sent some videos, but apparently the situation is not so clear cut. The search/calendar was a red herring, as starting from today also shows the wrong behaviour, but not always.
As to when the view becomes synced, if I go forward, it corrects that day, and also the previous day, but when I go back some more, it not necessarily stays OK.
I noticed that unfortunately it is not always repeatable. When I step slowly, sometimes it show the correct data, but when I jump quickly 3-4 days back, at least in my tests, it’s always wrong.
@lmpinto thanks, the quick-versus-slow detail is the useful part, and it’s all on BIG-936.
A change for this has been made. It isn’t in 1.8.0, so you may still see it there (1.8.0’s day-swipe fix, BIG-928, is a separate one). I’ll say so in this thread when it ships, and if you still see it after that, tell me here.
