Edit private places type
Hi Matt, I am currently living in China and Google services are not available here, so I have to create most places manually. I wonder if there will be a private place type editing feature. Another wired thing is that I could see most places on the mapbox map, but they never show up in the places search list.
@bmusgi two separate things there, so two answers.
Private place type: today the only thing you can edit on a private place is its name, which is why it shows the generic private-place icon. Letting you set a category on a place, private ones included, is tracked as BIG-512, and I’ve added your voice to it.
Places on the map but not in the search list: that depends which list. If you mean the search on a visit’s edit screen (tap a visit, then type in the search bar at the top), only places near that visit are searched, so a place you made somewhere else won’t show up there. The Places tab has no search box; it lists places by country, then city.
Either way, could you send a screenshot of the list where a place is missing, one of the map showing that place, and the Arc version you’re on? That’ll show me which list it is.
Ah, for this one that’ll be because Mapbox is only used for the map view itself. It doesn’t feed into the Place Results list, which is solely from Google Places.
The China specific exception to the use of Google Places is filed as BIG-832, and already has your voice on it. Though I think Mapbox isn’t a likely contender there either, so even with that done, the names you see on the map won’t necessarily match the results seen in the Place Results list. But if/when BIG-832 happens, you’d at least get much better place results in China than you get now.
