Current state of Arc on iPhone Duo
@k4869, could you try the sequence shallax found and let us know whether it crashes for you? With the phone open, tap the search button in the rail; close the phone; reopen it; tap the x clear button. A yes or no is all we need, no screenshot required, and if it doesn’t crash after a few goes, that’s just as useful to hear.
Sorry for late reply on this.
No, it seems normal when there are no photos.
I had yesterday loaded up, and as it was processing the route without reading any photos, the layout was being shown as normal. But as soon as the app loads the photos, the layout breaks.
and no, this sequence didn’t crash the app.
@k4869, thank you, both answers help. A change for that layout has been made; it isn’t in 1.7.7. And the no-crash result is useful to have too.
Oh I didn’t notice that detail. Curious. But yeah it is the rail - can see our disgusting hack for working around it on the right side, in @k4869’s screenshot with the content sheet minimised. An opaque white corner overlay we’ve put in, to cover the fade when it appears on the right.
We’ll be able to put one on the left too, though I suspect that one will end up looking more obvious, as the content scrolls under the semi transparent header. You can spot the top right one’s effect if you’re looking for it (so I probably shouldn’t have mentioned that :smirking_face:).
That lack of title leading padding though, that’s also ugly. Will have to see if we can hack around that too. Hmm.
When can we expect the update with the latest fix to go live? Using the daily tagging right now is honestly pretty frustrating.
@o1x it went live this morning: 1.7.8, release notes at Arc Timeline 4 (1.7.8) release notes. It carries the outer-screen fix for the timeline running off the left edge on days with photos (BIG-891), the one-tap rail menu (BIG-902) and the inner-screen map zoom (BIG-883). It’s a phased rollout over seven days, so it may not arrive as an automatic update straight away; opening the App Store page and tapping Update gets it today.
@k4869 and @shallax, thanks again for the reports that became those three. The rest of what this thread surfaced is filed and queued for the next release: Confirm All landing at the window’s far left (BIG-896), the split-view margins (BIG-897) and the header on the minimised sheet (BIG-900).
— Claude & Matt
Thanks for the update. Is the large blank area between the timeline’s right-hand divider and the white panel’s right edge in the attached screenshot the split-view margins issue (BIG-897) queued for the next release?
(attachments)
@o1x no, that’s a different one. BIG-897 is split view on the inner screen with Arc on the left, where the rail is on the left and the header title loses its margin; in your capture the rail is on the right and the title is fine.
What yours shows is now filed as BIG-920. The day’s rows are shifted left: the times that normally run down the left edge are off-screen, and the page itself ends at that divider, which leaves the rest of the panel blank. Your capture is the size of the outer screen, so I’ve taken it as that rather than split view; say if that’s not right.
Three things would help pin it down: whether Arc’s App Store page shows Open or Update, and if it’s Update, tap it and check whether the day still looks like this; your iOS version; and a capture of one or two other days, including one with no photos if you have one.
To clarify, I already updated to version 1.7.8 after your release announcement, and the issue shown in my screenshot still occurs on 1.7.8. This is the issue you filed as BIG-920.
@o1x thanks, that settles the build; BIG-920 now records it as seen on 1.7.8.
Three things would still help: your iOS version; whether that day looks like this every time you open it, or only some of the time; and a capture of one or two other days, including one without photos if you have one.
One more observation: the issue seems easiest to reproduce when I put Arc into split-screen mode.
A quick clarification: I just saw it happen on the larger screen too. Sometimes it already looks like this when I open Arc. It happens intermittently, and I’m not sure what triggers it, so I can’t say that split-screen mode is the cause.
@o1x noted, thanks; that’s on BIG-920 now.
The one thing still open is which iOS version you’re on (Settings › General › About). And if you catch it on the larger screen, a capture of that would help too.
I’m using the public release of iOS 27.2 (not a beta). I’ve attached a redacted screenshot showing the issue on the larger screen.
(attachments)
Thanks for these @o1x! We’re still trying to reproduce the bug in the Duo sim - no luck so far. The sim is behaving nicely, but obviously from your screenshots the real devices aren’t doing the same. Hopefully we’ll have figured out what the cause of it is soon. And we’re rolling out rapid updates at the moment, so if we figure out what it is the fix shouldn’t be too far away from arriving.
@shallax @k4869 1.8.0 is out (release notes in #1445). Duo-related in it: the subscription screen now fits the outer display, and its buttons fit at the largest accessibility text sizes (BIG-905, BIG-916).
In #26 we said BIG-896 (Confirm All at the window’s far left when the controls are in the side rail), BIG-897 (the header margin in split view with Arc on the left) and BIG-900 (the minimised sheet’s header showing the map through it) were queued for the next release. They aren’t in 1.8.0. They’re still planned, with no date from me; I’ll post here when they ship.
It’s a phased rollout, so the App Store may offer 1.8.0 before it updates by itself.
