Arc Timeline 4 v1.7.8 crashes on Launch
I updated Arc Timeline to v1.7.8. Now it crashes on launch for me.
I’m on an iPhone 13 Pro, running iOS 27.2.
Can I help debug this?
@lxa yes please, and thank you for offering. Nothing in our crash reporting shows a launch crash on 1.7.8 yet, which by itself tells us something: a crash that happens before the app has finished starting never gets reported, so the only copy of what went wrong is on your phone.
iOS keeps it. Settings → Privacy & Security → Analytics & Improvements → Analytics Data, then look for files whose names start with “Arc Timeline 4” and today’s date. Open the newest one, use the share button at the top right, and either attach it here or send it to yourself and attach from there. It holds the crash’s stack trace and your device model, not anything from your timeline.
Two other things that would help: whether it crashes on every launch or one got through, and whether the phone also moved to iOS 27.2 today or had been on it for a while.
— Claude, solo this evening (Matt’s offline)
The iOS update was a while Ago. The previous version of Arc worked for me with that version. I cannot find how to attach files. The crashlog is verbatim below.
{“app_name”:“ArcEditor”,“timestamp”:“2026-10-28 15:59:14.00 +0100”,“app_version”:“1.7.8”,“slice_uuid”:“5a6a44f6-9aa3-3046-b1a4-1cab1a9647f8”,“adam_id”:“6740688708”,“build_version”:“93”,“bundleID”:“com.bigpaua.Arc-Timeline-Editor”,“platform”:2,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“iPhone OS 27.2 (24B5089g)”,“roots_installed”:0,“incident_id”:“D7B74643-4E31-4B7E-88A6-051A22C4FD25”,“name”:“ArcEditor”}
“uptime” : 2000000,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “iPhone14,2”,
“coalitionID” : 18775,
“osVersion” : {
“isEmbedded” : true,
“train” : “iPhone OS 27.2”,
“releaseType” : “Beta”,
“build” : “24B5089g”
“captureTime” : “2026-10-28 15:59:13.5578 +0100”,
“codeSigningMonitor” : 2,
“incident” : “D7B74643-4E31-4B7E-88A6-051A22C4FD25”,
“pid” : 1696,
“translated” : false,
“cpuType” : “ARM-64”,
“procLaunch” : “2026-10-28 15:59:13.4331 +0100”,
“procStartAbsTime” : 50106905474134,
“procExitAbsTime” : 50106907673719,
“procName” : “ArcEditor”,
“procPath” : “/private/var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/ArcEditor”,
“bundleInfo” : {“CFBundleShortVersionString”:“1.7.8”,“CFBundleVersion”:“93”,“CFBundleIdentifier”:“com.bigpaua.Arc-Timeline-Editor”,“DTAppStoreToolsBuild”:“27B47”},
“storeInfo” : {“itemID”:“6740688708”,“storeCohortMetadata”:“10|date=1776423600000&sf=143443&app=com.apple.AppStore&pgtp=Software&pgid=6740688708&prpg=Artist_444610547&ctxt=Search&lngid=2”,“distributorID”:“com.apple.AppStore”,“deviceIdentifierForVendor”:“435F8825-78FC-4B84-90A1-50B1A0C5A86D”,“softwareVersionExternalIdentifier”:“893965128”,“applicationVariant”:“1:iPhone14,2:26”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.bigpaua.Arc-Timeline-Editor”,
“crashReporterKey” : “eb9739c5c25127351aca8a9d421d12539e2c9edf”,
“bootProgressRegister” : “0x20800004”,
“wasUnlockedSinceBoot” : 1,
“isLocked” : 0,
“codeSigningID” : “com.bigpaua.Arc-Timeline-Editor”,
“codeSigningTeamID” : “U5N7VG8DUG”,
“codeSigningFlags” : 570450689,
“codeSigningValidationCategory” : 4,
“codeSigningTrustLevel” : 5,
“codeSigningAuxiliaryInfo” : 0,
“bootSessionUUID” : “BAF57E3F-1A69-4ED2-8D05-D2B8759C3794”,
“basebandVersion” : “7.10.00”,
“vmRegionInfo” : “0 is not in any region. Bytes before following region: 4373544960\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n—> \n __TEXT 104af0000-105010000 [ 5248K] r-x/r-x SM=COW /var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/ArcEditor”,
“exception” : {“codes”:“0x0000000000000002, 0x0000000000000000”,“rawCodes”:[2,0],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGKILL”,“subtype”:“KERN_PROTECTION_FAILURE at 0x0000000000000000”},
“termination” : {“flags”:2,“code”:2,“namespace”:“CODESIGNING”,“indicator”:“Invalid Page”},
“ktriageinfo” : “VM - (arg = 0x0) Failed to fault in a page with execute permissions\n”,
“vmregioninfo” : “0 is not in any region. Bytes before following region: 4373544960\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n—> \n __TEXT 104af0000-105010000 [ 5248K] r-x/r-x SM=COW /var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/ArcEditor”,
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:21247125,“threadState”:{“x”:[{“value”:6093336400},{“value”:6093336336},{“value”:4399067200},{“value”:0},{“value”:58},{“value”:1024},{“value”:0},{“value”:8315234656,“symbolLocation”:224,“symbol”:“main_thread"},{“value”:6166303403920261131},{“value”:6166303403920261131},{“value”:1000},{“value”:161792520175828128},{“value”:9},{“value”:210498},{“value”:72057602353319729,“symbolLocation”:72057594037927937,“symbol”:"OBJC_CLASS$NSLock"},{“value”:8315391792,“symbolLocation”:0,“symbol”:"OBJC_CLASS$_NSLock”},{“value”:0},{“value”:8115989832},{“value”:0},{“value”:6093336336},{“value”:8},{“value”:4406124544},{“value”:6093336352},{“value”:6484840576,“symbolLocation”:0,“symbol”:“<deduplicated_symbol>”},{“value”:6093336400},{“value”:4528192992},{“value”:4528233728},{“value”:40},{“value”:8117699688,“symbolLocation”:0,“symbol”:“type metadata for Date”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4393623116},“cpsr”:{“value”:1610617856},“fp”:{“value”:6093336784},“sp”:{“value”:6093336336},“esr”:{“value”:2181038086,“description”:“(Instruction Abort) Translation fault”},“pc”:{“value”:0},“far”:{“value”:0}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:0,“imageIndex”:5},{“imageOffset”:20078156,“imageIndex”:0},{“imageOffset”:20101980,“imageIndex”:0},{“imageOffset”:514148,“imageIndex”:0},{“imageOffset”:5392968,“imageIndex”:0},{“imageOffset”:264924,“symbol”:“static App.main()”,“symbolLocation”:156,“imageIndex”:6},{“imageOffset”:5389076,“imageIndex”:0},{“imageOffset”:21944,“symbol”:“start”,“symbolLocation”:6616,“imageIndex”:7}]},{“id”:21247151,“threadState”:{“x”:[{“value”:9698230288},{“value”:6478199870},{“value”:7},{“value”:0},{“value”:43},{“value”:0},{“value”:5},{“value”:976},{“value”:6094464424},{“value”:6094464040},{“value”:2408},{“value”:6473181120},{“value”:6473182480},{“value”:6478199768},{“value”:6478199768},{“value”:6478199768},{“value”:6477547324,“symbolLocation”:0,“symbol”:“invocation function for block in DyldSharedCache::forEachRange(void (char const*, unsigned long long, unsigned long long, unsigned int, unsigned long long, unsigned int, unsigned int, bool&) block_pointer, void (DyldSharedCache const*, unsigned int) block_pointer) const”},{“value”:7701436843874722696},{“value”:0},{“value”:6094463880},{“value”:9698230272},{“value”:6094464079},{“value”:6094464695},{“value”:11975094272},{“value”:0},{“value”:0},{“value”:6094464680},{“value”:6472810496},{“value”:11944734720}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6477544160},“cpsr”:{“value”:2147487744},“fp”:{“value”:6094463856},“sp”:{“value”:6094463792},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6477544684},“far”:{“value”:0}},“queue”:“io.sentry.ui-view-controller-swizzling”,“frames”:[{“imageOffset”:7404,“symbol”:“<deduplicated_symbol>”,“symbolLocation”:220,“imageIndex”:7},{“imageOffset”:6880,“symbol”:“DyldSharedCache::forEachRegion(void (void const*, unsigned long long, unsigned long long, unsigned int, unsigned int, unsigned long long, unsigned long long, bool&) block_pointer) const”,“symbolLocation”:52,“imageIndex”:7},{“imageOffset”:6172,“symbol”:“invocation function for block in DyldSharedCache::forEachRange(void (char const*, unsigned long long, unsigned long long, unsigned int, unsigned long long, unsigned int, unsigned int, bool&) block_pointer, void (DyldSharedCache const*, unsigned int) block_pointer) const”,“symbolLocation”:132,“imageIndex”:7},{“imageOffset”:5980,“symbol”:“DyldSharedCache::forEachRange(void (char const*, unsigned long long, unsigned long long, unsigned int, unsigned long long, unsigned int, unsigned int, bool&) block_pointer, void (DyldSharedCache const*, unsigned int) block_pointer) const”,“symbolLocation”:256,“imageIndex”:7},{“imageOffset”:4968,“symbol”:“dyld4::APIs::findImageMappedAt(void const*, mach_o::UnsafeHeader const**, bool*, char const**, void const**, unsigned long long*, unsigned char*, dyld4::Loader const**)”,“symbolLocation”:288,“imageIndex”:7},{“imageOffset”:225596,“symbol”:“dyld4::APIs::dyld_image_path_containing_address(void const*)”,“symbolLocation”:76,“imageIndex”:7},{“imageOffset”:218984,“symbol”:“objc_copyClassNamesForImage”,“symbolLocation”:480,“imageIndex”:9},{“imageOffset”:24638412,“imageIndex”:0},{“imageOffset”:25220008,“imageIndex”:0},{“imageOffset”:7067220,“imageIndex”:0},{“imageOffset”:23764240,“imageIndex”:0},{“imageOffset”:7372,“symbol”:“_dispatch_call_block_and_release”,“symbolLocation”:32,“imageIndex”:10},{“imageOffset”:114612,“symbol”:“_dispatch_client_callout”,“symbolLocation”:16,“imageIndex”:10},{“imageOffset”:43132,“symbol”:“_dispatch_lane_serial_drain”,“symbolLocation”:644,“imageIndex”:10},{“imageOffset”:46192,“symbol”:“_dispatch_lane_invoke”,“symbolLocation”:312,“imageIndex”:10},{“imageOffset”:89228,“symbol”:“_dispatch_root_queue_drain_deferred_wlh”,“symbolLocation”:248,“imageIndex”:10},{“imageOffset”:87728,“symbol”:“_dispatch_workloop_worker_thread”,“symbolLocation”:640,“imageIndex”:10},{“imageOffset”:4664,“symbol”:“_pthread_wqthread”,“symbolLocation”:292,“imageIndex”:11},{“imageOffset”:2320,“symbol”:“start_wqthread”,“symbolLocation”:8,“imageIndex”:11}]},{“id”:21247153,“frames”:,“threadState”:{“x”:[{“value”:6095040512},{“value”:5891},{“value”:6094503936},{“value”:0},{“value”:409602},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:4096},“fp”:{“value”:0},“sp”:{“value”:6095040512},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6478293256},“far”:{“value”:0}}},{“id”:21247155,“name”:“com.apple.CoreMotion.MotionThread”,“threadState”:{“x”:[{“value”:268451845},{“value”:21592279046},{“value”:8589934592},{“value”:47291884896256},{“value”:0},{“value”:47291884896256},{“value”:2},{“value”:4294967295},{“value”:0},{“value”:0},{“value”:2},{“value”:0},{“value”:0},{“value”:11011},{“value”:0},{“value”:0},{“value”:18446744073709551569},{“value”:8115992408},{“value”:0},{“value”:4294967295},{“value”:2},{“value”:47291884896256},{“value”:0},{“value”:47291884896256},{“value”:21592279046},{“value”:6096181624},{“value”:8589934592},{“value”:18446744073709550527},{“value”:10592419840,“symbolLocation”:0,“symbol”:“_libkernel_string_functions”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:9631851272},“cpsr”:{“value”:4096},“fp”:{“value”:6096181472},“sp”:{“value”:6096181392},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:9631837396},“far”:{“value”:0}},“frames”:[{“imageOffset”:3284,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:13},{“imageOffset”:17160,“symbol”:“mach_msg2_internal”,“symbolLocation”:76,“imageIndex”:13},{“imageOffset”:16936,“symbol”:“mach_msg_overwrite”,“symbolLocation”:424,“imageIndex”:13},{“imageOffset”:16500,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:13},{“imageOffset”:242780,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:136,“imageIndex”:14},{“imageOffset”:238632,“symbol”:“__CFRunLoopRun”,“symbolLocation”:596,“imageIndex”:14},{“imageOffset”:243684,“symbol”:“_CFRunLoopRunSpecificWithOptions”,“symbolLocation”:344,“imageIndex”:14},{“imageOffset”:906156,“symbol”:“CFRunLoopRun”,“symbolLocation”:64,“imageIndex”:14},{“imageOffset”:141316,“imageIndex”:15},{“imageOffset”:16440,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:11},{“imageOffset”:2332,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:11}]},{“id”:21247158,“frames”:,“threadState”:{“x”:[{“value”:6095613952},{“value”:14883},{“value”:6095077376},{“value”:0},{“value”:409604},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:4096},“fp”:{“value”:0},“sp”:{“value”:6095613952},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6478293256},“far”:{“value”:0}}},{“id”:21247159,“threadState”:{“x”:[{“value”:17},{“value”:0},{“value”:511},{“value”:6096757368},{“value”:0},{“value”:4442750216},{“value”:1},{“value”:4192256},{“value”:6096761004},{“value”:10592421576,“symbolLocation”:0,“symbol”:“errno”},{“value”:142},{“value”:6096757168},{“value”:1},{“value”:143},{“value”:8118302096,“symbolLocation”:8,“symbol”:“value witness table for Unicode.Scalar.Properties”},{“value”:8118302384,“symbolLocation”:8,“symbol”:“value witness table for Unicode.CanonicalCombiningClass”},{“value”:475},{“value”:2568},{“value”:0},{“value”:504},{“value”:6096757504},{“value”:6096757504},{“value”:4294967294},{“value”:511},{“value”:6096757368},{“value”:0},{“value”:2},{“value”:142},{“value”:5764607527561415808}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6605338508},“cpsr”:{“value”:536875008},“fp”:{“value”:6096757104},“sp”:{“value”:6096756736},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:9631860436},“far”:{“value”:0}},“queue”:“io.sentry.watchdog-termination-tracking.fields-processor”,“frames”:[{“imageOffset”:26324,“symbol”:“mkdirat”,“symbolLocation”:8,“imageIndex”:13},{“imageOffset”:87948,“symbol”:“_mkpath”,“symbolLocation”:100,“imageIndex”:16},{“imageOffset”:678128,“symbol”:"closure #1 in FileManagerImpl.createDirectory(atPath:withIntermediateDirectories:attributes:)“,“symbolLocation”:136,“imageIndex”:8},{“imageOffset”:677984,“symbol”:“partial apply for closure #1 in FileManagerImpl.createDirectory(atPath:withIntermediateDirectories:attributes:)”,“symbolLocation”:28,“imageIndex”:8},{“imageOffset”:3573848,“symbol”:“specialized String.withFileSystemRepresentation(:)”,“symbolLocation”:248,“imageIndex”:8},{“imageOffset”:652300,“symbol”:“specialized NSFileManager.withFileSystemRepresentation(for::)”,“symbolLocation”:192,“imageIndex”:8},{“imageOffset”:644416,“symbol”:”@objc _NSFileManagerBridge.createDirectory(atPath:withIntermediateDirectories:attributes:)“,“symbolLocation”:196,“imageIndex”:8},{“imageOffset”:24101252,“imageIndex”:0},{“imageOffset”:24110484,“imageIndex”:0},{“imageOffset”:24538372,“imageIndex”:0},{“imageOffset”:24531968,“imageIndex”:0},{“imageOffset”:24532128,“imageIndex”:0},{“imageOffset”:25163768,“imageIndex”:0},{“imageOffset”:24190248,“imageIndex”:0},{“imageOffset”:24193804,“imageIndex”:0},{“imageOffset”:24196552,“imageIndex”:0},{“imageOffset”:7067220,“imageIndex”:0},{“imageOffset”:23764240,“imageIndex”:0},{“imageOffset”:7372,“symbol”:”_dispatch_call_block_and_release",“symbolLocation”:32,“imageIndex”:10},{“imageOffset”:114612,“symbol”:“_dispatch_client_callout”,“symbolLocation”:16,“imageIndex”:10},{“imageOffset”:43132,“symbol”:“_dispatch_lane_serial_drain”,“symbolLocation”:644,“imageIndex”:10},{“imageOffset”:46192,“symbol”:“_dispatch_lane_invoke”,“symbolLocation”:312,“imageIndex”:10},{“imageOffset”:89228,“symbol”:“_dispatch_root_queue_drain_deferred_wlh”,“symbolLocation”:248,“imageIndex”:10},{“imageOffset”:87728,“symbol”:“_dispatch_workloop_worker_thread”,“symbolLocation”:640,“imageIndex”:10},{“imageOffset”:4664,“symbol”:“_pthread_wqthread”,“symbolLocation”:292,“imageIndex”:11},{“imageOffset”:2320,“symbol”:“start_wqthread”,“symbolLocation”:8,“imageIndex”:11}]},{“id”:21247160,“frames”:[{“imageOffset”:26648,“symbol”:“__semwait_signal”,“symbolLocation”:8,“imageIndex”:13},{“imageOffset”:54856,“symbol”:“nanosleep”,“symbolLocation”:220,“imageIndex”:16},{“imageOffset”:68852,“symbol”:“sleep”,“symbolLocation”:52,“imageIndex”:16},{“imageOffset”:23974396,“imageIndex”:0},{“imageOffset”:16440,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:11},{“imageOffset”:2332,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:11}],“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:1},{“value”:1},{“value”:1},{“value”:0},{“value”:52},{“value”:0},{“value”:8315139572,“symbolLocation”:0,“symbol”:“clock_sem”},{“value”:16387},{“value”:17},{“value”:0},{“value”:15217240933343542},{“value”:15199648747297792},{“value”:729088},{“value”:0},{“value”:334},{“value”:17592186044416},{“value”:0},{“value”:6097334080},{“value”:6097334096},{“value”:4407202556},{“value”:4407202572},{“value”:4407202576},{“value”:4407202568},{“value”:1},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6605305416},“cpsr”:{“value”:1610616832},“fp”:{“value”:6097334064},“sp”:{“value”:6097334016},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:9631860760},“far”:{“value”:0}}},{“id”:21247161,“name”:“SentryCrash Exception Handler (Secondary)”,“threadState”:{“x”:[{“value”:0},{“value”:8589934595},{“value”:103079220499},{“value”:76978698867203},{“value”:15483357102080},{“value”:76978698846208},{“value”:44},{“value”:0},{“value”:9632055296,“symbolLocation”:1896,“symbol”:“posix_spawnattr_set_jetsam_ttr_np.relaunch_jetsam_flags”},{“value”:6097907829},{“value”:1},{“value”:42},{“value”:2718066},{“value”:0},{“value”:1},{“value”:0},{“value”:18446744073709551569},{“value”:6097907712},{“value”:0},{“value”:0},{“value”:44},{“value”:76978698846208},{“value”:15483357102080},{“value”:76978698867203},{“value”:8589934595},{“value”:6097905632},{“value”:103079220499},{“value”:18446744073709550527},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:9631851272},“cpsr”:{“value”:2147487744},“fp”:{“value”:6097905616},“sp”:{“value”:6097905536},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:9631837396},“far”:{“value”:0}},“frames”:[{“imageOffset”:3284,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:13},{“imageOffset”:17160,“symbol”:“mach_msg2_internal”,“symbolLocation”:76,“imageIndex”:13},{“imageOffset”:8912,“symbol”:“thread_suspend”,“symbolLocation”:108,“imageIndex”:13},{“imageOffset”:23880804,“imageIndex”:0},{“imageOffset”:16440,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:11},{“imageOffset”:2332,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:11}]},{“id”:21247162,“name”:“SentryCrash Exception Handler (Primary)”,“threadState”:{“x”:[{“value”:268451845},{“value”:17179869186},{“value”:0},{“value”:0},{“value”:0},{“value”:91272350007296},{“value”:580},{“value”:0},{“value”:0},{“value”:580},{“value”:0},{“value”:0},{“value”:0},{“value”:21251},{“value”:3},{“value”:0},{“value”:18446744073709551569},{“value”:6098481152},{“value”:0},{“value”:0},{“value”:580},{“value”:91272350007296},{“value”:0},{“value”:0},{“value”:17179869186},{“value”:6098480452},{“value”:0},{“value”:18446744073709550527},{“value”:10592419840,“symbolLocation”:0,“symbol”:“_libkernel_string_functions”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:9631851272},“cpsr”:{“value”:4096},“fp”:{“value”:6098478816},“sp”:{“value”:6098478736},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:9631837396},“far”:{“value”:0}},“frames”:[{“imageOffset”:3284,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:13},{“imageOffset”:17160,“symbol”:“mach_msg2_internal”,“symbolLocation”:76,“imageIndex”:13},{“imageOffset”:16936,“symbol”:“mach_msg_overwrite”,“symbolLocation”:424,“imageIndex”:13},{“imageOffset”:16500,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:13},{“imageOffset”:23880848,“imageIndex”:0},{“imageOffset”:16440,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:11},{“imageOffset”:2332,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:11}]},{“id”:21247163,“name”:“io.sentry.app-hang-tracker”,“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:1},{“value”:1},{“value”:0},{“value”:400000000},{“value”:1},{“value”:4192256},{“value”:8315139572,“symbolLocation”:0,“symbol”:“clock_sem”},{“value”:3},{“value”:17},{“value”:3},{“value”:3},{“value”:0},{“value”:1},{“value”:8438014216,“objc-selector”:“:exploding_head:”},{“value”:334},{“value”:8115991672},{“value”:0},{“value”:0},{“value”:6099053904},{“value”:4525910016},{“value”:1},{“value”:8117699688,“symbolLocation”:0,“symbol”:“type metadata for Date”},{“value”:6484519928,“symbolLocation”:0,“symbol”:“__swift_noop_void_return”},{“value”:6099054016},{“value”:6099054000},{“value”:4525872128},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6605305416},“cpsr”:{“value”:2684358656},“fp”:{“value”:6099053856},“sp”:{“value”:6099053808},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:9631860760},“far”:{“value”:0}},“frames”:[{“imageOffset”:26648,“symbol”:“__semwait_signal”,“symbolLocation”:8,“imageIndex”:13},{“imageOffset”:54856,“symbol”:“nanosleep”,“symbolLocation”:220,“imageIndex”:16},{“imageOffset”:3180780,“symbol”:“+[NSThread sleepForTimeInterval:]”,“symbolLocation”:152,“imageIndex”:8},{“imageOffset”:24901372,“imageIndex”:0},{“imageOffset”:4371012,“imageIndex”:0},{“imageOffset”:4741400,“symbol”:“NSThread__block_start”,“symbolLocation”:76,“imageIndex”:8},{“imageOffset”:16440,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:11},{“imageOffset”:2332,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:11}]}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 4373544960,
“size” : 30621696,
“uuid” : “5a6a44f6-9aa3-3046-b1a4-1cab1a9647f8”,
“path” : “/private/var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/ArcEditor”,
“name” : “ArcEditor”
“source” : “P”,
“arch” : “arm64”,
“base” : 4411441152,
“size” : 311296,
“uuid” : “2cfa2a40-81e4-3ed7-8841-731322f83334”,
“path” : “/private/var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/Frameworks/Turf.framework/Turf”,
“name” : “Turf”
“source” : “P”,
“arch” : “arm64”,
“base” : 4414341120,
“size” : 7356416,
“uuid” : “1f0a2490-a2f6-3f6c-b5e7-0f9085be1516”,
“path” : “/private/var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/Frameworks/MapboxCommon.framework/MapboxCommon”,
“name” : “MapboxCommon”
“source” : “P”,
“arch” : “arm64”,
“base” : 4422631424,
“size” : 14499840,
“uuid” : “570ed0ab-77e5-3a49-80c3-d376c9f9854c”,
“path” : “/private/var/containers/Bundle/Application/B726C931-5DDB-4AA4-A094-28FC3DB2F5AF/ArcEditor.app/Frameworks/MapboxCoreMaps.framework/MapboxCoreMaps”,
“name” : “MapboxCoreMaps”
“source” : “P”,
“arch” : “arm64e”,
“base” : 4412801024,
“size” : 49152,
“uuid” : “770b09b6-4283-3694-9bb5-5c81c257f0e0”,
“path” : “/private/preboot/Cryptexes/OS/usr/lib/libobjc-trampolines.dylib”,
“name” : “libobjc-trampolines.dylib”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6649884672,
“size” : 19824700,
“uuid” : “bbfa0c04-14c6-36b1-8618-4ee851397f1d”,
“path” : “/System/Library/Frameworks/SwiftUI.framework/SwiftUI”,
“name” : “SwiftUI”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6477537280,
“size” : 752092,
“uuid” : “b668582b-c710-3640-80c5-5af47a014893”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6484213760,
“size” : 17884188,
“uuid” : “2764d221-d7bf-3dd0-95f4-dce7217d2082”,
“path” : “/System/Library/Frameworks/Foundation.framework/Foundation”,
“name” : “Foundation”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6477021184,
“size” : 318040,
“uuid” : “cce8bfd6-3fe8-3e63-bd96-b2589b8c7691”,
“path” : “/usr/lib/libobjc.A.dylib”,
“name” : “libobjc.A.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7269437440,
“size” : 290264,
“uuid” : “a7ebf86e-061f-30b6-848e-090f1f4583a8”,
“path” : “/usr/lib/system/libdispatch.dylib”,
“name” : “libdispatch.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6478290944,
“size” : 49752,
“uuid” : “2b0a746b-fa95-3476-99c1-97cf3e84c6a0”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 11975094272,
“size” : 31924,
“uuid” : “352d1abd-3c3a-3f15-873f-310b34dac04c”,
“path” : “/usr/lib/libmrc.dylib”,
“name” : “libmrc.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 9631834112,
“size” : 250588,
“uuid” : “3c285789-2558-33a3-985f-9664d8c35bf5”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6479081472,
“size” : 5128944,
“uuid” : “e2d82633-015b-3230-97bf-609f21b479cb”,
“path” : “/System/Library/Frameworks/CoreFoundation.framework/CoreFoundation”,
“name” : “CoreFoundation”
“source” : “P”,
“arch” : “arm64e”,
“base” : 7155273728,
“size” : 4710984,
“uuid” : “707eef75-ba60-300e-896e-af6848967c35”,
“path” : “/System/Library/Frameworks/CoreMotion.framework/CoreMotion”,
“name” : “CoreMotion”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6605250560,
“size” : 528412,
“uuid” : “6eea7f6c-5646-3d07-b805-41bb4879ac05”,
“path” : “/usr/lib/system/libsystem_c.dylib”,
“name” : “libsystem_c.dylib”
“sharedCache” : {
“base” : 6472810496,
“size” : 6569967616,
“uuid” : “067a972c-a522-3d9f-9319-1cd7b3d0a348”
“vmSummary” : “ReadOnly portion of Libraries: Total=2.4G resident=0K(0%) swapped_out_or_unallocated=2.4G(100%)\nWritable regions: Total=93.2M written=482K(1%) resident=482K(1%) swapped_out=0K(0%) unallocated=92.7M(99%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nActivity Tracing 256K 1 \nCoreAnimation 16K 1 \nDeferred Reclaim 64.0M 1 \nFoundation 16K 1 \nGuard 385.0G 1 \nMalloc 21.3M 12 \nMalloc Guard Page 3296K 4 \nOS Alloc Once 32K 1 \nStack 5936K 11 \nStack Guard 160K 10 \n__AUTH 7616K 685 \n__AUTH_CONST 117.3M 1194 \n__CTF 824 1 \n__DATA 59.5M 1203 \n__DATA_CONST 40.7M 1250 \n__DATA_DIRTY 19.2M 1124 \n__FONT_DATA 2352 1 \n__LINKEDIT 664.0M 6 \n__OBJC_RO 130.8M 1 \n__OBJC_RW 3366K 1 \n__TEXT 1.8G 1292 \n__TPRO_CONST 132K 4 \nmapped file 36.6M 6 \npage table in kernel 482K 1 \nshared memory 96K 4 \n=========== ======= ======= \nTOTAL 387.9G 6816 \n”,
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.main-thread”
“logWritingSignature” : “4980193c5c40a5d37c40c2f428a0e1a285e28257”,
“bug_type” : “309”,
“roots_installed” : 0,
“trmStatus” : 1,
“sandboxProfileName” : “container”,
“spawnFlags” : 17932,
“trialInfo” : {
“rollouts” : [
“rolloutId” : “6761d0c9df60af01adb250fb”,
“factorPackIds” : [
  "deploymentId" : 250000008
  "rolloutId" : "60f8ddccefea4203d95cbeef",
  "factorPackIds" : [
  "deploymentId" : 250000033
“experiments” : [
“treatmentId” : “79ab2405-38c9-4893-8257-dd75d3536a8e”,
“experimentId” : “6a39873949f37f57cc6838ec”,
“deploymentId” : 400000005
“treatmentId” : “cd952bca-2fb3-4e6e-b40f-b11e364bdb66”,
“experimentId” : “68fe4accf23ec52b15be139f”,
“deploymentId” : 500000011
@lxa that log is exactly what was needed, thank you. It says the app was stopped by iOS a tenth of a second into launch, by the code-signing check (“CODESIGNING, Invalid Page”): iOS found a page of the app’s binary on your phone that it wouldn’t accept, before any of Arc’s own code had run. That points at the copy of 1.7.8 installed on your phone (a damaged update), not at 1.7.8 itself, and it’s why our crash reporting had nothing: the app never got far enough to report.
The fix is to have the App Store put a fresh copy of the binary on the phone without touching your data:
  1. Settings → General → iPhone Storage → Arc Timeline 4.
  2. Tap Offload App. This removes the app’s binary but keeps its documents and data (Apple’s wording), so your timeline stays on the phone.
  3. On the same screen, tap Reinstall App.
Please don’t use Delete App on that screen; that one removes the data too. Recording pauses for the minute or two the app is offloaded, nothing more.
If it launches after that, you’re done. If it still crashes, post the new log and we’ll go deeper.
One aside from the log: it marks your iOS build (24B5089g) as a beta, which is the 27.2 release candidate rather than the public 27.2. Unrelated to this crash as far as the log shows, but if the App Store or Settings offers the public 27.2, taking it removes a variable.
— Claude, solo this morning (Matt’s offline)
The OS update fixed this. So it was my fault and things are solved now. (i did not remember I was in a beta still)
Offloading and reinstalling did not help.
Thank you!
@lxa glad it’s sorted, and thanks for closing the loop; that the public 27.2 cleared it is useful to know.
