As title says, never ending update from App Store, still ongoing 2 days later. Extremely slow updates have been an issue for many many versions but this one just doesn’t end.
Two things worth trying. Long-press the Arc Timeline 4 icon on your Home Screen and choose Pause Download, then long-press again and Resume — that’s often enough on its own. If it doesn’t budge, restart the phone; a stalled download usually picks up again after that. Downloading and installing updates is the App Store’s own job rather than something the app takes part in, which is why the fix lives on that side.
If it happens again on a future update, a screenshot of the App Store page plus your iOS version would give us something concrete to look at.
Every time I update, I also have this problem: the update won’t finish. The solution is to close Arc Timeline. The update can then complete, and you simply need to reopen Arc afterwards.
But why on earth does the update fail like this?
Please note that Arc is the ONLY app I’ve seen having such upgrade freeze issue, whichever iPhone model or iOS versions I’m using, and for every upgrade. I don’t really see what the App Store would have to do with it, targeting your app uniquely and consistently this way? Best guess some extremely slow (in my unfortunate case) script is running as part of the upgrade process that is the culprit.
It really is Arc and not your other apps — and there’s a mundane reason for it. In practice the installer waits for Arc to not be running, and Arc is the unusual one: it’s recording in the background, so it’s rarely in the fully-stopped state the installer wants. Most apps spend nearly all their time suspended or closed, so the install slips in unnoticed; with Arc it waits. Nothing of ours runs during an install, an app has no say in the installer’s timing, and nothing on our side can see that an update is waiting. So if you’d rather not wait it out: close Arc from the app switcher and the update goes through. Recording picks up again when you open it. A phone restart does the same thing the long way round.
I should add: iOS does stop apps itself in order to facilitate auto updates. It’s iOS’s job to do that, and it does correctly do that for most updates for most users. These cases where it hasn’t done that is an iOS bug. Most auto updates succeed without fuss, with iOS automatically stopping the app, doing the update, then restarting the app afterwards.
But yes, until Apple make that process more reliable, if you’re waiting on an update the workaround is to swipe the app closed, let the update finish, then relaunch the app again afterwards. Essentially doing iOS’s steps for it, because it dropped the ball that time around.
